Hello; I am trying to view my BI cams within Tiny Cam Pro using my Nvidia Shield.
I have installed TinyCam Pro and added the BI server IP port 81 and I am able to see the Camera Index.
how would I be able to view each of my cams on their own as well? I am not able to click on the cams within the index view.
I was reading that if I change to channel from 1 to 3 then that would display my first cam. Is that accurate? If that is the case, would I need to add new camera entries under manage camera all pointing to the BI server IP and just keep changing the channel?
Is there a better way to do all this?
thank you!
thank you!
