You are doing something wrong. Of course you can play video and audio together. There is never a reason to use vlc.Is there plans for BI to play audio and video together in it's media player? Sucks having to use VLC and not being able to zoom in on a part of the video. Or am I missing something/doing something wrong?
Its always worked simply by playing it back. There is no reason to convert. Are you saying it plays back just with no audio?Yeah, I tried it again. If the C-910 is paired with any of my cams, it will not play in bi. It's pretty straight forward in the audio settings. Like I said before, I sworn it was working. So i'm guessing it's a broken update. Maybe.........
Are you recording to MP4? or bvr? If MP4 you must install the codec for playback, there is a link on the blue iris site.I tried everything. That's why i'm here. It just didn't seem right. I know dog gone well it was working a couple of weeks ago, maybe a month ago.
audio will not play at fast forward speeds.It does work! I have to go to record tab, video format and compression, Blue Iris DVR (check mark that), then re-encode with settings (h264-h264/mpeg-4 AVC.
Then it works.
But, if your playing a video more than 1x it will not work.
Note, that even if you set the usb cam to direct to disk, its not using direct to disk because the usb cam is not sending an h.264 stream. That is one reason to not use USB cameras for blue iris among others.I'm happy now! But have to use vlc for older video's, wish I knew. But, I could have sworn it was recording and playing video/audio using direct to disc 2 weeks ago, maybe a month ago.
