Video clip size
Woody70
Jun 9, 2020
155
36
Hemet California
I have Blue Iris v4, I recently changed cameras and now the video clips size has gone from under 2mb to some of them 7mb I have tried to change the image format but it always goes back to 1920 x 1080 is there any way to make them smaller like the camera was before which was 1280 x 720 , also the camera date and time shows on the live video but does not show on the recordings and I don't have it set to direct to disc.
Thank you for any help.
What brand and model cameras?
try optimizing your system and see what changes.
I have tried to set it in the camera but the only thing is I couldn't find any settings other than H265x- H264- H264+ and for the time and date there is nothing anywhere in the settings. The time and date does show in Blue Iris live video
it just does not in the recordings.
Reactions: djernie
what do you mean by size, where are you determining size ?
a 1920 x 1080 is 2.25 times bigger than 1280 x 720 for a single frame.
Need have the older cameras frame rate and the new cameras frame rate.
I looked at the ZG2622MW manual there is almost no configuration options in the manual.
What every you do , do not scan the QR code, on this chinese camera
Reactions: djernie
I downloaded the app called iSCEE from google play, but there is not much information or options in it. I was able to get it connected wireless to my router but any info just isnt there.
Sorry to say but these cameras are Chinese pieces of junk, send them back or put them into the garbage.
:welcome:
My standard welcome to the forum message.
Read Study Plan before spending money
Cameras are for surveillance to get information for after the fact.
Please read the IP Cam Talk Cliff Notes and other items in the IP Cam Talk Wiki. (read on a real computer, not a phone). The wiki is in the blue bar at the top of the page.
Read How to Secure Your Network (Don't Get Hacked!) in the wiki also.
Quick start
1) If you do not have a wired monitored alarm system, get that first
2) Use Dahua starlight cameras or Hikvision darkfighter cameras if you need good low light cameras.
3) use a VPN to access home network (openVPN)
4) Do not use wifi cameras.
5) Do not use cloud storage
6) Do Not use uPNP, P2P, QR, do not open ports,
7) More megapixel is not necessarily better.
8) Avoid chinese hacked cameras (most ebay, amazon, aliexpress cameras(not all, but most))
9) Do not use reolink, ring, nest, Arlo cameras (they are junk), no cloud cameras
10) If possible use a turret camera , bullet collect spiders, dome collect dirt and reflect light (IR)
11) Use only solid copper, AWG 23 or 24 ethernet wire. , no CCA (Copper Clad Aluminum)
12) use a test mount to verify the camera mount location. My test rig: rev.2
13) (Looney2ns)If you want to be able to ID faces, don't mount cams higher than 7ft. You want to know who did it, not just what happened.
14) Use a router that has openVPN built in (Most ASUS, Some NetGear....)
15) camera placement use the calculator... IPVM Camera Calculator V3
16) POE list PoE Switch Suggestion List
17) Camera Sensor size, bigger is general better Sensor Size Chart
18) Camera lens size, a bigger number give more range but less field of view. Which Security Camera Lens Size Should I Buy?
Cameras to look at
IPC-T5442TM-AS-LED . Review IPC-T5442TM-AS-LED (Full Color, Starlight+) - 4MP starlight
.................... Dahua IPC-T5442TM-AS-LED review
IPC-T5442TM-AS ..... Review-OEM 4mp AI Cam IPC-T5442TM-AS Starlight+ - 4MP starlight+
IPC-B5442E-ZE ...... Review - OEM IPC-B5442E-ZE 4MP AI Varifocal Bullet Camera With Starlight+
IPC-T2347G-LU ...... Review of the Hikvision OEM model IPC-T2347G-LU 'ColorVu' IP CCTV camera. (DS-2CD2347G1-LU)
IPC-HDW2231R-ZS .... Review-Dahua IPC-HDW2231RP-ZS Starlight Camera-Varifocal
IPC-HDW2231T-ZS-S2 . Review-OEM IPC-T2231T-ZS 2mp Varifocal Starlight Camera
IPC-HDW5231R-ZE .... Review-Dahua Starlight IPC-HDW5231R-ZE 800 meter capable ePOE
IPC-HFW4239T-ASE ... IPC-HFW4239T-ASE
IPCT-HDW5431RE-I ... Review - IP Cam Talk 4 MP IR Fixed Turret Network Camera
IPC-T5241H-AS-PV ... Review-OEM IPC-T5241H-AS-PV 2mp AI active deterrence cam
IPC-T3241-ZAS ...... Review-OEM IPC-T3241-ZAS 2mp AI Lite series Varifocal -- 2mp AI Lite series Varifocal
IPC-HFW2831T-ZS ... Review-Dahua IPC-HFW2831T-ZS 8MP WDR IR Bullet Network Camera -- 8MP Bullet 1/1.8” sensor variable focus.
DS-2CD2325FWD-I
N22AL12 ............ New Dahua N22AL12 Budget Cam w/Starlight -- low cost entry
IPC-T2347G-LU....... Review-Loryta OEM 4MP IPC-T2347G-LU ColorVu Fixed Turret Network 4mm lens & Junction Box -- 4MP ColorVu
.................... Review of the Hikvision OEM model IPC-T2347G-LU 'ColorVu' IP CCTV camera.
Other dahua 4MP starlight Dahua 4MP Starlight Lineup
My preferred indoor cameras
DS-2CD2442FWD-IW
IPC-K35A Review-Dahua IPC-K35A 3mp Cube Camera
If interested in Blue Iris and other setup items see the following post
Before asking a question search the forum first...
The best way to search the forum is to use Google
In the google search window enter.. site:ipcamtalk.com ?????? ..where ?????? is the items/terms you are interested in.
Example site:ipcamtalk.com PALE MOON BROWSER
Read,study,plan before spending money ..... plan plan plan
Test do not guess
