Vertically mounted PTZ?
magma1447
Aug 8, 2018
2
Sweden
Hi, I am looking into buying my first dome PTZ camera from Hikvision. The problem is that I would like to have it vertically mounted on a wall, without a bracket. The reason behind that is that I want it as discreet as possible for that particular location.
Is it possible to have the PTZ models vertically mounted? I am using "normal" domes on walls without any issues. What I am afraid of is that the rotation will be weird when panning and tilting the PTZ. For those with fixed angles I have manually fixed the rotation of course.
The particular model I am looking at is DS-2CD2785FWD-IZS - Hangzhou Hikvision Digital Technology Co. Ltd. .
No, you will get issues with the pan and tilt, as the directions are not correct anymore.
Pan will turn into a "clock" and tilt will go all wonky also. Best way is to mount it like it should be.
Here is a example of a vertically mounted PTZ (motion sickness aware) :D :
If you need to mount a camera vertical, you better go with a non ptz camera.
Reactions: aristobrat
Thank you SkyLake, you pretty much confirm what I was afraid of. I might end up buying a regular one then to be honest, at least for this case. Super nice that you provided an example video. I have been searching Youtube for hours. :) Much appreciated.
