Version 4.1.8
4.1.8 - September 23, 2015​
  • With a new option on the camera properties Schedule tab, You may now instruct a camera to continue using its own schedule even if you use the profile override buttons or it's changed in another way. ​
  • The red border placed around triggered cameras in remote group streams is now 2 pixels wide ​
  • The Record tab in camera properties has once again undergone a revision. Now, JPEG snapshots may be assigned to their own folder and/or subfolders. In addition, the folders and filename formats are now profile-sensitive--you may change these as the profile changes. If a video file is open for recording as the video folder or filename changes, the recording file will be cut and re-opened. ​
  • Cloned cameras will now all reset when the parent is disabled, deleted, or reset, allowing one of the dependent windows to become the new parent ​
  • The Options/Users page now offers the ability to limit user session time and the time they must wait between sessions ​
  • Disabling a user on Options/Users will immediately invalidate any current session for that user​
