I a hobbyist in photography and in the camera world, zoom lenses (which I am thinking equate to "vari-focal" lenses) generally have a smaller aperture than prime lenses ("fixed-lens" lenses).
Thus prime lenses capture more light and are better in low light. Often prime lenses are cheaper too because they don't have a complicated zoom mechanism. As an example, the common 50mm f/1.8 lens often quite cheap. And compared to the MUCH more expensive 24-70 f/2.8 zoom lens, the cheap and cheerful 50mm f/1.8 captures more than twice the amount of light (f/1.8 is more than 1"stop" of light "faster" than f/2.8; 1 stop of light being twice as much light)
Is this the same in the security camera world?
For example, a camera that is well thought of around here is the vari-focal:
EmpireTech 4MP 2.7mm-12mm Lens Turret Camera IPC-T5442T-ZE White, currently $189 USD.
But there is a similar fixed lens camera:
Loryta 4MP Turret AI IP Camera Fixed Lens IPC-T5442TM-AS 2.8mm, currently $159 USD. This one being the 2.8mm "fixed lens" model, there are others also available in 3.6 and 6mm.
As expected the fixed lens Loryta is cheaper than the vari-focal Empiretech.
However, there isn't a mention of the aperture (the f/1.8, f/2.8 etc. that I talked about earlier when it comes to camera lenses).
What is the aperture of a fixed-lens camera like the Loryta? And if it is significantly larger, will cameras like the Loryta be better in low light?
