I have 6 5mp cameras recording at 15fps. I also have a 3TB hard drive.
I am trying to conserve HD space so i am deciding to try and use Triggered+continuous on 3 cameras that dont see much action (but still record) then when the cam detects motion they will record at 15fps before going back to low frame rate after a certain time.
My setting on record tab are:
Record:Triggered+continuous 0:01 min for 0.0 sec <-- (only 1 frame)
Options: Combine cut video each 1hrs 0min 4.0gb
The problem im having is one of the cameras using these settings work perfect. The other 2 indicate they are recording "red box around camera view" but nothing is being saved unless there is a motion alert. Ive compared multiple times that the settings match on both cameras but two of my cameras still will not record unless there is an alert.
Any ideas?
Any ideas?
