- Nov 25, 2016
- 857
- 2,336
I have been experimenting with the new Wyze OG Telephoto camera with 3X optical zoom, and I have learned that it can capture license plates on moving vehicles from a distance of about 40 feet, where the vehicles are traveling between 25 and 30 mph.
Here's the good:
(1) The camera costs only $29, and it's weatherproof. You will need to install a $10 SD card for continuous recording.
(2) Stationary plates can be viewed up to about 70 feet.
(3) Moving plates can only be viewed up to about 40 feet. The interesting thing is that it isn't motion blur that reduces the readability, but instead the lossy compression of the camera. Unfortunately, there's no way to adjust that.
The bad:
(1) Motion blur is terrible at night (not surprising), so capturing moving plates after sunset is out of the question. I plan to do more testing in the coming days to determine the viewing range of stationary plates at night.
(2) You need to pay Wyze for their Cam Plus service if you want recordings in the cloud, or vehicle detection. Otherwise you can get by with free motion alerts and the SD card to check plates after the fact.
Granted, this is only a partial solution for LPC, and only works over a limited distance, but it might be useful in some residential and business applications. Plus, it is ridiculously cheap, and very easy to set up as long as you have a smartphone and WiFi. I doubt that anyone on this forum would want to rely on a camera like this, but it might be useful in situations where cost and convenience overrule everything else.
Wyze Cam OG Telephoto LPC at 40 feet
Here's the good:
The bad:
