Hi all,
I have been running BI with CPAI for some time now, and the issue I keep encountering is that the setup sometimes doesn't trigger/alert or flag movements, and at other times, it triggers/alerts incorrectly.
I have been "tweaking" the system based on other forum members' settings and suggestions, but without any luck. After reading more posts, I was considering using the built-in AI in the cameras. However, my question is: how good is the built-in AI compared to CPAI?
The cameras I use are from Andy IPC-T5442TM-AS running version V2.840.0000000.26.R, Build Date: 2023-12-21.
What would your recommendation be? Should I stick with CPAI or switch to the built-in AI from the cameras?
