I've been trying to get a Foscam vnt6656g6A40 IP camera to work with a Hikvision NVR. I've never set up a camera using RTSP before (I JUST RECENTLY found out that RTSP is the transmission protocol as I thought before that was ONVIF). I've been trying different combinations of settings in the custom protocol, but I just can't get this camera online. I didn't know where to find the RTSP settings for this camera, but I found this page:
Foscam Forum • View topic - How to use RTSP and HTTPS for HD cameras
I'm not exactly sure what port the camera uses for RTSP, but according to my camera settings, the http port is 80 so I've been using that:
Dropbox - CameraPort.jpg - Simplify your life
I've been editing the custom protocol on the NVR (trying a combination of ports 80, 554, with password, without, etc) to see if I could hopefully fluke out and get the right settings, but I've been pulling my hair out trying to get this right:
From the website I posted above, this is what I'm thinking my RTSP feed should be, but it doesn't appear to work:
rtsp://[email protected]:80/videoMain
I was wondering if I need to include the port number or user
ass in the stream URL as the port can be specified (and the username
assword can be entered when modifying the camera settings)?
Dropbox - NVRRTSPSettings.jpg - Simplify your life
Dropbox - NVRCameraSettings.jpg - Simplify your life
I tried using VLC to open the stream, but I just keep getting
"Connection failed:
VLC could not connect to "192.168.1.41:88".
Your input can't be opened:
VLC is unable to open the MRL 'rtsp://admin
[email protected]:88/videoMain'. Check the log for details."
I really have no idea what I'm doing, or even know if this camera can support it, but I'd appreciate any suggestions to try. I guess this is why you should only buy ONVIF compatible cameras.
"Connection failed:
