Hi All!
I am trying to setup a reverse SSH tunnel to access a Blue Iris server that sits behind CGNAT. (No port forwarding, DDNS etc.) I already have machine access through RDP but I would also like web access.
From the Blue Iris server I issue the command:
ssh -N -R 8181:localhost:81 [email protected]
When browsing to my.vps.machine.com:8181 I get ERR_CONNECTION_REFUSED.
The Blue Iris server is (for now) also running Apache and if issuing the command:
ssh -N -R 8181:localhost:80 [email protected]
I get the website served perfectly when visiting my.vps.machine.com:8181.
I have tried using nginx on the VPS in conjunction with the reverse SSH tunnel to forward (proxy_pass) a my.vps.machine.com request to 127.0.0.1:8181 which results in 502 BAD GATEWAY.
The nginx method works when connecting to my Apache server on port 80.
I have tried running Blue Iris server on port 80 with same result.
I have not been able to access any Blue Iris web server logs as I cannot find any. How do you enable web server log?
Does anyone know how to get around this issue? Could it have anything to do with the "Remote, external (WAN/Internet) access" setting in Blue Iris? I have tried different options here: local IP, VPS IP NAT IP but nothing works so far.
Thanks!
Thanks!
