Using cameras as motion sensors to turn on lights
dastrix
Aug 18, 2017
193
21
Hi All,
Im doing this but seeing alot of false positives with motion, such as when it rains the lights will go on/off and theres lots of recording at night
Im confused as to the min contrast/make time, which would be most suited to remove these positives? The cameras record motion just fine during the day and capture the objects without an issue
Im thinking a combination of a longer make time and less contrast
thanks
Have you given Sentry a try? They have AI for human detection that is very accurate. I get almost no false positives now that I use Sentry.
Sorry what is sentry?? I'm not familiar with it. The system I use is fine, its just I want to tweak the motion settings of the cameras
Reactions: dastrix
