- Jul 9, 2016
- 27
- 15
How do I use the cam number on Tinycam to select a specific camera or camera group?
the channel numbering in Tinycam seems random in terms of which BI cam it shows on Tinycam. Sometimes it shows multi cams in a split screen on Tinycam when I select one of the higher numbers for channel number.
is there a trick to this channel number mapping? What does the number refer to??
thanks
using Tinycam Pro 14.7.1 (from Amazon store) on a 4k firestick.
BI is version 5.3.2.9 x64 (9/18/2020)
thanks
