Hi Folks,
Starting a new thread as this doesn't seem to have been covered anywhere before.
My situation: HIKVISION DS-2CD2532F-IWS (with Alarm I/O pigtail) and a DSC 1832 SECURITY SYSTEM WITH DSC 151 MOTION SENSOR
The Goal: have the DSC Motion sensor trigger alarm based recording on HIKVISION
The alarm system is configured to expect a NC circuit for all sensors including the motion sensor. Motion sensor works perfectly on it's own.
On the motion sensor, there is NC, C, and +, - terminals that are connected back to the DSC Panel
On the HIKVISION, the PIGTAIL has Alarm I, O, and GND.
What terminals do i connect from PIR to the PIGTAIL? I tried NC->I and C> GND and that didn't work.
Thanks!
Thanks!
