- Oct 31, 2017
- 4
- 1
I am still making up my mind as to which of the two 30x Optical Zoom Dahua cameras to get - either the SD50430U or the SD50230U. I have a few questions which your answers will hopefully make my decision easier.
I'll give you some background as to how I'll be using the camera. The camera will be providing a near-live (3 - 5 second delay) video stream of rowing regatta races to the attending crowd. Races take place over a 2km course, with "masters" races taking place over 1km. At the moment, only people with powerful binoculars can see the start of the 2km races. I intend to set the camera up at the finish line and, using the PTZ feature, zoom up on the start. I should get about 84m of coverage at a distance of 2km with a 2.4deg field of view, which is ideal. I would then control the camera, either through the SmartPSS (or similar) software or through bespoke software written against the Dahua SDK, and track the boats all the way down the course and across the finish line.
If there's an interest in this video stream, I plan to purchase another PTZ and place it at the start line and, using a radio link, broadcast this stream as well. I'd use OBS (Open Broadcaster Software | Home) to cut between the 2 video streams.
The reasons I've chosen to use "security cameras" and not broadcast spec PTZ cameras are :-
- The video from a broadcast camera would inevitably have be compressed and transmitted, and a "security camera" already does this with minimal latency.
- The image quality doesn't have to meet Sky Sports/BBC Sports broadcast specifications. The final stream will be scaled to a maximum resolution of 1280x720.
- Cost. "Security cameras" are cheaper.
- Which of the 2 models (SD50430U, SD50230U) will give me a crisper image at full zoom. I'm guessing the 4Mega Pixel model.
- Is there a way to increase the video bit rate above the rates listed in the SmartPSS. Could this be done via the Dahua SDK/API? I need around 20Mbps at 4 Mega Pixels, as the ripples and waves on the water require a lot of data to "describe" these high contrast, high motion, organic objects. These randomly changing objects "steal" bandwidth from other, more important areas of the image, namely the boats and their crews.
- Am I crazy for even thinking about doing it this way?!
