My house uses cat5 cables for the phone lines, I only wired one for the actual phone and the rest I can use for other purposes.
I have yet to terminate any of them, other than the one used for the phone and a hack on one for testing. I plan on using it for PoE cameras and a few PoE Wireless Access Points.
The problem I have is the cables don't actually run to my patch panel, which ever wall has the jack i have about 3-5ft of extra cable in the basement and i need to run each wire at 10ft to reach my patch panel. The idea is if i was to get the phone jacks wired they would daisy chain the cables.
Whats the best way to length these cables?
Is it a bad idea to run PoE with couplers and Cat5 cables?
Is it a bad idea to mix cat5 and cat6 cables when used for PoE?
I was planning on installing a RJ45 male plug on the cat5 phone wire and using a punch down keystone on the new cat6 cable i'd run, so its becomes a coupler. I haven't been able to find punch down couplers on both ends otherwise i would have went with that.
We'll also be finishing the basement at some point and worried the r45 plug may come loose or something, it has happened before.
