Hello Everyone I need some Advice!, I wanted to see if anyone has tried running Blue Iris on a laptop using a usb 3.0 Network Adapter, and if so how many cameras are you using? Do you think using my newer Toshiba laptop would give me better performance while using the USB 3.0 network adapter?
I have 6 Cameras total, But Blue Iris is only setup for 3 recording in HD and 1 in SD and i wanted to know if it would be an issue since i want to add more and upgrade my 3 x FI8918w to HD versions. It looks like the Toshiba would give me better specs performance overall since my HP laptop seems to be at 65-75% usage when recording (Motion) 4 cameras and i noticed my FI9900p is dropping frames already. I contacted Blue Iris and they recommended i come here and ask my question
This is the adapter i was looking at StarTech USB 3.0 to Gigabit Ethernet NIC Network Adapter
https://www.amazon.com/gp/product/B0095EFXMC/ref=crt_ewc_title_dp_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Running BlueIris with latest updates
2 x FI9803P
1 x FI9900P
3 x FI8918w
Dedicated Network using TRENDnet 8-Port Unmanaged Gigabit Switch
Current laptop with built in newtork card
HP Pavilion G7 Notebook
Intel i5-2430m [email protected] 6GB Ram
New laptop is Toshiba Satellite Radius P55W-B5220
Intel i5-4210U Up to 1.70GHz with Intel® Turbo Boost Technology 2.40ghz
- 8GB RAM
2 x FI9803P
1 x FI9900P
3 x FI8918w
- 8GB RAM
