URL for generic ipc365 IP camera to be used with ispy
slickochet
Jan 4, 2020
22
2
northern ireland
Hi there
I recently bought a number of generic IP cameras that I can currently access through an android app and their own proprietary app but I would like to be able to use them with ispy too. I have had no luck getting access to them or URLs to use with ispy even using its scanners and wizards.
The camera were branded as klzhe and show up as ipc365 when looking for devices on my router. I have tried a number of username and password combos suggested on ispys website and other forum pages but still no luck.
Many suggested to use ports 23456 or 34567 with combinations like admin/root etc.
The camera itself looks like the attached picture. I have seen this camera sold under many other brand names with slight variations in colour etc so there may be a few different iterations of them knocking about that could use different credentials etc.
Would anyone have any ideas on how to access this camera and/or get a broadcast URL to use with ispy?
Many thanks in advance.
I found the brand "victure" that looks like it, specifically the model PC520.
Cam also be found on amazon UK here.
I'd try some URL's on iSpy for Victure here using VLC with port 554 and also 34567 for RTSP .
Good luck! You may find it's locked into P2P by scanning QR code.
Yeah thanks! I saw that on Amazon recently too and was wondering if it might be more common now....
It still doesn't seem to be listed in iSpy's wizard.
What username/password/channel would you think would be best to use?
Your guess is as good as mine. Pehaps admin/admin/0 or 1 after a reset?
Sorry I can't offer any better insight.
Thanks for the help. Sadly, still not had any luck trying a bunch of combinations with your suggestions.
You could be right that they're locked to P2P. In order to pair them with the phone app originally, you need to search for them with the camera set in pairing mode and then the phone and the camera make a strange series of chirping noises back and forth which pairs them.
Reactions: TonyR
Greetings,
Glad to see others have purchased this model, I recently purchased "360Eyes IPC365" from amazon.
After lots of research I was unable to find anything. So I started doing some probing of my own,
Here are some of my findings:
Using the camera default application, Navigate the settings and turn on ONVIF.
IPC365 Cams are hosted over rtsp protocol on port 554 using authentication,
Example: rtsp:/admin:[email protected]:554/live/ch0
Playing with the channels will give different resolutions.
The PTZ controls are being proxied to some server in China back to the camera.
Sending the following packets gives your basic controls
Code:
/ Right
cc dd ee ff 77 4f 00 00 e3 12 69 00 48 00 00 00 00 00 00 00 af 93 c6 3b 09 f7 4b 01 01 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
/ Left
cc dd ee ff 77 4f 00 00 e3 12 69 00 48 00 00 00 00 00 00 00 af 93 c6 3b 09 f7 4b 01 01 00 00 00 00 00 00 00 00 00 00 00 fb ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
/ Down
cc dd ee ff 77 4f 00 00 e3 12 69 00 48 00 00 00 00 00 00 00 af 93 c6 3b 09 f7 4b 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 fb ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
/ Up
cc dd ee ff 77 4f 00 00 e3 12 69 00 48 00 00 00 00 00 00 00 af 93 c6 3b 09 f7 4b 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Signature:
Code:
Functions:
Code:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Aw man you got me really excited there! But I still can't connect to them using your example URL and changing IP address to one of mine.
The issue may be that there's no way to turn on onvif in the app my cameras provided. It's called klzhe and onvif settings are nowhere to be found in it.
I feel like I'm so close but so far!
Try advanced port scanner this will tell you what ports are open
on your cameras ip address and if a web server is active you
can log in from this software
also if camera is onvif you could try onvif device manager
some chinese cameras onvif is on port 1018 or 8899
Hi Everyone,
I bought one cam 360eyes S (IPC365) on Wish. I received it in perfect time.
I didn't find how to display on iSpy stream of that cam... No problem on VLC, but nothing on iSpy ...
After a lot of search, i resolved my problem
Enter this on "Plugin VLC"
rtsp:/admin : xxxxxx@YOURCAMIP : 554/cam/realmonitor?channel=1&subtype=1
Tell me if it' good ;)
Bests regards
Hi thanks for the reply!
Sadly I can't get a picture with that URL either. I used admin for user and 123456 for password. I'm not even sure if these are correct or not.
@slickochet ,
I gotta say this, my man....you have a lot more patience than I do. I think I would have moved on by now to some more mainstream (pun intended) cameras. :cool:
EDIT:
What about this URL for VLC:
Code:
rtsp:/YourCamIP:554/cam/realmonitor?channel=1&subtype=1
Insure there's 2 forward slashes after "rtsp"and forget about the username and password for now...VLC will ask you for them.
Well I'm also very cheap and I've bought 5 of them now for over £100 so I want to exhaust all my options before having to spend more money....haha.
And the return window for them has long since closed I'd say.
Understood.
See my "EDIT" in post #12.
Thanks! But still no connection with this URL either. Doesn't ask for a username or password and just fails....
Have you have any luck yet? I just got a couple of these cameras. The app I used to configure them (365EyeS pro) also doesn't seem to have the ability to enable onvif. I'd love to see the settings people have used successfully in VLC, I tried the suggested rtsp uri above but it just doesn't connect. I just get VLC is unable to open the MRL 'rtsp:/MYCAMIP:554/cam/realmonitor?channel=1&subtype=1'.
The app on the phone won't connect unless the camera has full external web access, and I don't want it having that. I just want whatever it's doing kept purely in my network. You can't even set it up without it being able to phone home.
No still no joy. Can't seem to find any way to connect to it other than the properitary app "Klzhe".
