I once in a while change the profile of my Blue Iris Install using a URL command. For Example "http://192.168.1.160:81/admin?profile=4&trigger&user=XXXX&pw=XXXXX" The problem is that it does not seem to reset back to the default profile in the schedule so the profile just sticks there in the selected profile.
I know you can toggle the lock with admin?profile=-1 but it seems like I could cause some issues with this if this depending on the state of the system. Is there a way to explicitly set the system to the default profileof the camera through a URL command or maybe Json?
