I have been running BI on a windows 7 computer for many years now. Its worked ok. with 3 cameras. That's all I have. Yes its a bit slow but has worked for me.
It appears that outlook mail does not work with this version of BI software version 4. Yes I know there are work arounds but I would rather have it work out of the box.
So it appears the proper solution is to upgrade to 5. Since I'm already a user it appears and upgrade to 5 is about 30 dollars.
My question is if BI 4 has worked well enough for me on this computer, will BI 5 work on this computer. I believe it is an intel Core 2 4300 1.80 x2
I recognize that may will say it as I have seen in the past that it should not work with BI 4 but it does. This is the only thing this computer does.
Second question is, how easy is it to upgrade. I would hate to loose all the settings I have set up.
Thank you.
Thank you.
