I purchased a cheap onfiv poe camera that was advertised as having a 360 FOV. As I am not experienced yet I should have know it was bullocks. THe image is not fully 360/180 degrees FOV and the service support with the seller leads no where as one can expect from shady sellers on those popular web sites from our friends in the east.
The camera was sold as having these specs;
I tried placing a different lens that hopefully would work better so after waiting for too long for it to arrive I can't get a sharp image because of the lens shaft length is not similar to the original lens.
The specs of the new lens are;
Model: M12-1.0-5MP-F-FL
Mount: M12
Aperture: F2.2
Resolution: 5 Megapixel
Image Form 1/3"(φ3.27mm)
Focal Length: 1.0mm
BFL: 2.68mm
MBF: 1.93mm
IRIS: Fixed
M.O.D.: 0.15m
Weight: 10g
Dimension: Φ24x20.61mm
Would anyone know how I can gather more information of the original lens suck as focal length or aperture or what have you? This all in the hopes I can find a lens that does work with this specific ip camera board and sensor and does provide a 360/180 FOV
| Camera | |
| Product Name | 1.3 Megapixel IP 360 Degree Panoramic Camera |
| Model No. | LM-IF360C8IRB |
| DSP | High sensitivity CMOS sensor, Hislicon 3518C DSP |
| Imaging Sensor | 1/3" CMOS Sensor |
| Resolution | 1280(H)*960(V), 1.3 Megapixel |
| Lens | 1.2mm 360degree Panoramic megapixel lens |
| IR LEDs | 30pcs IR Leds |
| Night Vision Distance | 25-30 IR Distance |
Mount: M12
Aperture: F2.2
Focal Length: 1.0mm
BFL: 2.68mm
MBF: 1.93mm
IRIS: Fixed
M.O.D.: 0.15m
Weight: 10g
