There may be some confusion as the steps required to upgrade the Longse RoboCat LRDC60S500 5MP IP camera; this post is intended to help those who may be having trouble with the upgrade procedure.
There are two (2) steps to the upgrade...
Now that you've been forewarned here is the procedure...
1) Download the archive I've posted at the very bottom of this post and extract it to a folder on a local drive.
2) Open Internet Explorer 11 and browse to your LRDC60S500 camera's IP address.
3) In the camera interface login page enter your camera's "User Name" and "Password" and press the "Login" button (Note that the login account you use must have camera Administrator privileges).
4) Navigate to the camera's "maintenance page" as shown in the "IPC upgrade operation.pdf" (Unfortunately I can't tell you the steps to navigate to this page because I've updated both of my cameras to the new interface...but it's in there and you'll find it).
5) Click on the "Scan" (Chinglish for "Browse") button and browse to, and select, the "3516A_IMX178_W_6.1.25.3.fls" file which is located in the extraction folder you created in Step 1.
6) Click on the "Upgrade" button and sit back while the new firmware is written to your camera. DO NOT interrupt power to your camera during the upgrade countdown or pain and suffering will be brought upon your house. After the upgrade procedure has completed the camera will probably reboot and you will probably be presented with the camera interface login page again. There is no need to log in again.
7) Shutdown all Internet Explorer browser instances.
8) Navigate to the extraction folder you created in Step 1.
9) Right click on the "HsWebPlugin.exe" executable and then left click on "Run As Administrator" and complete the installation of the "HsWebPlugin.exe" executable.
10) At this point I would reboot the LRDC60S500 camera (either by logging into the camera and rebooting it from the camera interface or but interrupting power to the camera).
That's it! You should be done and when you log back into the camera you should be experiencing the new "Hikvision-Like" user interface!
Good luck and, if you have any problems please contact Alastair, Nayr, Klasipca or one of the other members who know what they are doing...not Qlueless Q!
[TABLE="class: grid, width: 500"]
[TR]
[TD="align: center"]Files Contained Within The Installation Archive[/TD]
[/TR]
[TR]
[TD="align: center"] 3516A_IMX178_W_6.1.25.3.fls[/TD]
[/TR]
[TR]
[TD="align: center"] HsWebPlugin.exe[/TD]
[/TR]
[TR]
[TD="align: center"] IPC new interface introduction.ppt[/TD]
[/TR]
[TR]
[TD="align: center"] IPC upgrade operation.pdf[/TD]
[/TR]
[/TABLE]
[TR]
[TD="align: center"][/TD]
[TD="align: center"]Firmware
Version
[/TD]
[TD="align: center"]Software
Version
[/TD]
[TD="align: center"]Web
Version[/TD]
[/TR]
[TR]
[TD="align: center"]Before Update:[/TD]
[TD="align: center"]Opps: Forgot to record it![/TD]
[TD="align: center"]5.1.51.3[/TD]
[TD="align: center"]5.1.50.1[/TD]
[/TR]
[TR]
[TD="align: center"]After Update:[/TD]
[TD="align: center"]3516A_IMX178_W_6.1.25.3[/TD]
[TD="align: center"]6.1.23.5[/TD]
[TD="align: center"]6.1.23.160608[/TD]
[/TR]
[/TABLE]
[TR]
[TD="align: center"]The Installation Archive[/TD]
[/TR]
[TR]
[TD="align: center"]Click Here To Download[/TD]
[/TR]
[/TABLE]
***And a big shout out and many thanks to @ klasipca who uncovered this new firmware***
- Step 1: Installing the new firmware
- Step 2: Installing the new web component to enable the new user interface
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
Version
[/TD]
Version
[/TD]
Version[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
