spagnum.dk
I got the abnormal shutdowns issue with my DS-7608NI-SE/P NVR as well. I have 2TB WD Purple in it. Look like abnormal shutdowns is NOT fixed with the new firmware 3.0.15 build150528 . I have a temporary way to fix this, just re-format HDD everytime abnormal shutdowns happened to fix the issue for few months then it still come back. This is not the good way because we will lost all the footage (more than 6 weeks in my 2TB HDD) but look like this the only way to stop abnormal shutdowns for few months.
Abnormal shutdowns make the CCTV system not reliable at all. This is a really serious problem with DS-7600NI-SE devices but don't know why Hikvision still not fix this issue after years??? I've been used and installed lots of 7600 series systems but really disappointed Hikvision about this issue.
PS: I have trouble to update firmware from 3.0.9 to 3.0.15 as well. The 7608NI-SE/P was bricked and I had to used TFTP to un-brick it. I used TFTP to update firmware for a bricked nvr but had to attempted more than 30 times to get it connect to 192.0.0.64 and transmit the firmware to NVR, all others times only stoped at "Device [192.0.0.64] test tftpserver" then no responded. Had to power off and on more than 30 times to get TFTP connect and transmit, WTH???
I have the same problem with my DS-7604NI-SE/P, but I have to format my 2TB WD Purble HD after approx 30 days.
So if I buy the new model DS-7604NI-E1/4P/A do you think this will solve my problem, is this a better NVR.
I'm desperate to get a stable system
