Looking to Upgrade some of my cameras, currently have a mix of Wyze 4, Reolink, Hikvision. I just got a Reolink Trackmix POE and then found out it's only 1080. I love the features of it but would like better.
Needs:
Wide FOV 90+ only for 1 camera, any others can be the normal 60ish (Don't want to run 2 cameras side by side. tree on other side of house so not a good setup for 2 cameras on corners in front)
Auto Tracking
Auto Zooming
More concerned about the 30-60ft range
Good IR distance, Don't like the spotlight cams
Under $700/Cam
Needs:
Auto Tracking
Auto Zooming
Under $700/Cam
