New here and thanks in advance for any guidance. New house, old camera system in need of an upgrade. Very handy just not an electronics wizard, so need a bit of guidance on using the existing coax cables. Current system is DVR with 4 wired cameras. Coax and 12V wire to each camera. Very solid professional install, DVR in need of replacement etc, so looking to upgrade to digital for enhanced features etc. and trying to use existing wiring as upgrade to ethernet wire would be difficult.
Looking at new NVR with 4 wired cameras. Wire runs are not long, center of house to the 4 corners. Not set on a system yet, so open to advice there. So here is my main question on the BNC-ethernet conversion. Here are the options I see:
- I am familiar with the POE converters that will allow me to run the power and signal over the coax. Due to space constraints at the camera end, these converters will be difficult if not impossible to use, not to mention cost of these
- I could use the separate existing 12V to power the camera separately, this leaves me with just a BNC to ethernet conversion (unpowered). Is this possible? I see cheap and small BNC Balun converters, can these handle the signal quality and data needed for the newer high resolution cameras? I can't find any information on this part. Other ideas?
- WiFi cameras are a possibility, but need to figure out the power supply issue. It appears the newer cameras want to use USB power connectors at 5.5 VDC for powered cameras. I have 12V and no 120V outlets near any of the cameras. This introduces a whole new complication, in that I cannot get power to the cameras. Don't really want to deal with batteries.
At a bit of a loss here , short of pulling new cable, this is not looking as easy as it should be. As with everything else in our world, the equipment keeps upgrading and changing Appreciate any insight on this.
