I have 19 cameras, and one is really bugging me with it's record delay. I.E. the clip starts once the motion is in the center of the frame. As a control I have another brand's camera with the same Resolution, Same Frame rate and Same settings in BI; and it doesn't have the same issue. I'm starting to think it's an issue with these camaeras, as when you attempt to use VLC or Tinycam to watch this camera directly there is a HUGE delay before you see anything as compared to the control camera. Here are the details.
UPDATE SOLVED.
I Was going to delete this after writing this all down helped me figure out the problem. For anyone with the same issue, it's with H.265+ and Variable Bit Rate vs H.265 and Constant Bit Rate. Once I changed the setting on the Hikvision to CBR and H.265, everything began to work well.
These are my notes to help others.
- Ben
Problem Camera
Hikvision DS-2CD2T42WD-I8 - Firmware v5.4.4 build 161125
Camera Settings
Resolution: 2688x1520
FPS: 20
IFrame Interval: 50 (can't change this option on camera)
H.264+: On
Max Bitrate:4096
Bitrate Type: Variable (only option)
BlueIris Settings
Receive Buffer: 20MB
Max Rate: 20fps
MAKE time: 1sec
Video Format: Direct-to-Disc
Pretrigger Video Bugger: 5sec
Functional Control Camera
Amcrest IP4M-1025E - Firmware 2.400.0000.15.R, build : 2016-06-15
Camera Settings
FPS: 20
IFrame Interval: 20
Encode Mode:H.264H
Max Bitrate:4096
Bitrate Type: CBR
BlueIris Settings
Max Rate: 20fps
MAKE time: 1sec
UPDATE SOLVED.
- Ben
Problem Camera
Camera Settings
FPS: 20
H.264+: On
Max Bitrate:4096
BlueIris Settings
Max Rate: 20fps
MAKE time: 1sec
Camera Settings
FPS: 20
IFrame Interval: 20
Encode Mode:H.264H
Max Bitrate:4096
Bitrate Type: CBR
BlueIris Settings
Max Rate: 20fps
MAKE time: 1sec
