I have an Evtevision ES-N196 16ch 5MP NVR. It was working fine until I bought two new cameras to hook up.
I added 2 SV3C. One was a D13POE-5MPL-A and the other was a SV-B06POE-4MP-A. I couldn't get these too display. As the NVR is older then the two cameras I figured a firmware update might be the answer. I performed there update and it fixed the issue with those two camera. Great......but wait.
I have a camera because of it's physical shape and location I can not easily replace it with an IP camera. It is still the old analog but what I had did to get it to work with the NVR was get a Samasung single port encoder. Samasung/Hanwha Techwin SPE-101N. It's an anolog to IP converter and is ONVIF compliant. Now on the NVR it says not logged on. If I go to my PC I can punch in IP address and bring it up with no problems. I went over everything set in the NVR and even cleared stuff out and started over but nothing helps. Something changed in that firmware upgrade.
Any ideas or help would be greatly appreciated.
Thanks,
Ed KE2EAC
Thanks,
Ed KE2EAC
