I'm trying to monitor some Foscam IP cameras (FI9805EP) with a Uniview NVR304E and I'm running into a few issues that have me scratching my head. If I use ONVIF the cameras will connect up just fine but the Encoding Stream Type keeps coming up as Normal vs. Event type so I'm unable to draw/mark my Motion detection regions. So far I have been unable to find a setting on the cameras that seems to satisfy the NVR that it's an Event type stream.
My next thought was to do a Custom Protocol and try to do H.264 by manually entering the stream information but I've been unable to make that work either, in that manner using the URL, port, etc. it never connects, the Resource Path I've entered is rtsp:/<ip>:<port>/videoMain which should connect to the primary H.264 stream.
Anyone familiar with making this combination of equipment work? Thanks!
