Hi all. This is my first post, and I'm looking for some insight. I searched the forums and couldn't find an answer to my question so here goes:
Does anyone have experience with UniView's ColorHunter cameras? I have used the H-Series NiteColor cameras and liked them overall. I'm wanting to upgrade some cameras around my property, and am trying to decide which is the best option between these two. I would go with the turret style. Pros/cons to each?
I'm primarily concerned with the following:
1. Low light performance, and not as much with daylight performance.
2. Does the UniView stuff integrate with IVMS 4200/4500?
3. Overall image quality. NiteColor is 4mp, and ColorHunter is 5mp, but sensor and lens quality is more important to the overall image quality than raw megapixels. Is there a significant difference?
4. The event/smart event features I'm currently using are motion detection, and line crossing detection. The UniView's look like they may have more advanced algorithms than the H-Series stuff that would allow more precise and accurate alerts.
What else? I am looking forward to your insights and replies!
