Forgot to ask earlier... Are you interested in knowing of cams that it did not pick up in my scan?
All the rest of my various Dahua and Hikvision cams were found.
- Two are oddballs and probably not worth bothering with.
- One Hikvision DS-2CD2342WD does not appear.
- One Annke I61DR-1 (rebranded Hikvision Cube cam) using POE does not appear. BUT another of the same cams running wireless does appear as Hikvision.
My apologies... I did not check this forum thread for a while.
Sure, you can help me by doing a discovery via SADP tool and performing a Wireshark so I can check how SADP discovers DS-2CD2342WD and Annke I61DR-1 and then send me via email like describe in the following procedure:
I can even assist via remote access if this task is a bit tricky for you.
Many thanks and sorry for reply delay
