Hi everyone,
I remember reading a post about 3-4 years ago which described exact rules that someone used for their unfi firewall as well as VLAN setup for each. I used those and they worked flawlessly. I have since moved and had to start my Unifi setup from scratch because lost my backups of the controller. So now i am without rules etc...
My setup is as follows
Unifi USG
Unifi 48 port POE switch
Unifi AC AP HD x 1
Unifi AC AP Pro x 2
8 IP cams around the house, both inside and out
Qnap TS-1685 with Synology 3618 (i think) VM to run Surveillance Station now
Synology 1815+ to which all cams record to via Surveillance Station
A bunch of smart home stuff and other wifi connected stuff (ring doorbell, tvs, etc)
I want to be able to isolate all the cams so they do not see the light of day and cannot access the internet at all
I want to ensure that only internally i can access cams unless i set connect to a VPN from outside the house and only to that vlan
I want all the IoT stuff to not have access to internal network
There were a few more firewall rules which I had but dont remember them from the top of my head.
If anyone can share their set up who use the same network equipment (Unifi), that would be greatly appreciated.
Thanks in advance
Unifi USG
Unifi AC AP HD x 1
Unifi AC AP Pro x 2
Thanks in advance
