I have a Uniden DB1 and loaded the Uniden app on my iPhone. Tried to upgrade from 1.4.61 build 170821 to 1.4.62 build 180515 and it sat there for 4 hours without completing. I connected again and the DB1 still said it was upgrading. I have tried the HIKVision app and it still shows the firmware is upgrading. It seems to work but I’m not sure what firmware it is on. Already tried rebooting also deleted and reinstalling.
From reading a lot of the forum so far I think I can manually load the new firmware by loading it on a 32G microSD and booting it. I also read that the micro SD card should be FAT32 format. I downloaded the 180809 build from the Neely site but am unsure if it correct. The digicap.dav file has exec in a black icon. The other digicap.dav files are white. I use a MacBook pro and I know a lot of you use a PC.
Q1 Can I upgrade this doorbell via the microSD boot?
Q2 Is the digicam.dav with the exec in a black icon the correct file to use? (see pic)
Uniden tech support was virtually useless. They had no answers and denied that the camera is the same as HIKVison, Neely, or others. They also said the I couldn’t access the camera using safari on my MBP. Wrong! I used the rtsp://admin
[email protected]:554/streaming/channels101 and it came right up.
I turn to you my wise brothers for answers to my questions. Thanks in advance.
geo
geo
