I was hoping that someone here would be able to help me out. I recently purchased this camera. I got it all setup according to the instructions. However, when I remove the 8gb microsd card that came with the camera and put in my 32gb microsd class 10, the app is not reading the card. Under setting > storage status > it says no memory card. I used the program SD card formatter on windows 10 to format it. Perhaps I need to use a different software to format it? I looked in the Uniden one app and I do not see an option to force the camera to read the sd card. I have tried resetting the camera by pushing the reset button for 15 seconds and went through the whole setup process again and that did not work either. Anyone else have any ideas?
Also I tried logging into the web app via the IP address of the camera. I inputted my username and password and it saying my credentials are wrong. I KNOW for a fact that my username and password are correct. It gives you 6 attempts before it locks you out. Not sure what is going on there. Anyone have any tips for this problem?
