I am able to open the Blue Iris 4 help manual (BlueIris.chm), but I can't see the graphics. All the graphics are represented by an X. The text is all there, but sometimes the text refers to a picture which I can't see. For example, in Getting Started the text says, "When you start Blue Iris for the first time, here's what you'll see:". The only thing I see is an X where the picture should be.
I would appreciate any help on this.
I am running Windows 7. IE version 11. Blue Iris version 4.1.0.3 x64.
See screenshot below as an example:
