Dear Forum Community,
I am reaching out in a time of need for our church. We're struggling with a technical issue involving six ECI-T24F2 Hikvision cameras that are crucial to our building's security. Our limited budget as a religious organization means we cannot afford professional services or new equipment, making community advice our best hope.
Issue at Hand:
We are grateful for any assistance you can provide and thank you in advance for your support and kindness.
Warm regards,
EasyT
Issue at Hand:
- Failed SDAP Tool Attempts: Both our team and Hikvision technical support have unsuccessfully tried resetting the passwords using the SDAP tool and XML files.
- No Reset Button Available: On inspecting the cameras, we confirmed there is no internal reset button.
- Ineffective Use of Batch Configuration Tool: This tool did recognize all cameras but failed in the password reset process.
- Firmware Information: The cameras are running on firmware version V5.5.3 build 180629.
- Direct Connection to NVR: In a recent attempt, we connected the cameras directly to an NVR system belonging to a friend, which also supports Hikvision cameras. Unfortunately, this method too did not lead to a successful password reset.
- Network Configurations Checked: All possible network and firewall issues have been ruled out.
Warm regards,
EasyT
