- Aug 24, 2016
- 3
- 0
Hi, looking for help with playing a recorded video file.
BI v4.4.2.0 x64 (latest release)
W10
When trying to view a clip, I get the message at the top of the viewer "Unable to open file: 80040274"
In my folder where the clips are saved, that file has no "duration" attribute, where as other clips do.
I can not play the file in any other player
-VLC just does nothing
-W10 Movies&TV app shows error 0xc00d36c4
-Mediaplayer shows message "WMP encountered a problem while playing the file"
Clip is obviously corrupt for some reason.
There are 4 other clips in the folder (out of 92) that are the same issues. Other 88 play no problem in any player.
Sizes are 10mb-96mb.
There are other clips that are larger and play fine (up to 200mb)
Any ideas as to what's corrupting the files?
Any idea if the files are retrievable?
One other note, the thumbnail clip in the CLIPS side window shows an image, and it looks like it could be the actual image from the clip as I see our dog setting off the motion activation.
Which tells me that the file is being access within BI to get the thumbnail.
Thanks for any help!
Chris
W10
Chris
