I am trying to get a vpn working and am able to connect to my router, but can't get past the login screen on the NVR.
After I enter username and password it just sits there. Eventually it times out. But if I intentionally enter the wrong password, it immediately gives me "incorrect password or username".
I looked at the logs on my android client, it goes through the housekeeping and last event shows connected.
Using Android with openvpn client, asus rt-68 with built in VPN, and Dahua NVR.
Originally I had set up the NVR for P2P so I don't know if any of those settings are causing conflict.
The only thing I know for sure is I am able to make the vpn connection, it's just unresponsive past the login.
