I am unable to delete a clip. The duration of the clip is 0.0seconds. When I try to play it the message "Source file format is corrupt or you are missing components.................." comes up. When I try to delete the message "Could not delete item, it may be protected or in use". It is annoying not being able to get rid of a zombie clip. Any ideas? This is only the problem with this one clip.
Thanks for any help.
John
John
