I have a 8 port lorex fusion also running with BlueIris. I have two nic's on the BlueIris server and the second nic is plugged into the lorex switch with a static ip of the lorex system set.
I have 4 cameras on the house, all 4 connected to a switch in the attic which is then uplinked to the NVR. I also have 2 cameras about 1500ft down the drive using a fiber uplink to another switch. The cameras show on the NVR, but I cannot connect to the IP addresses of the two cameras from the BlueIris PC.
