Both have the starvis sensor but the the DH-SD8A840VI-HNI is the starlight camera. They both have all the same features and both will have a excellent picture.
If low light is the most important to you than the SD8A840VI-HNI is the winner at - Color: [email protected]; B/W: [email protected]; [email protected] (IR on)
Any idea as to why Dahua doesn’t put these low light sensor in their smaller ptz? Big sensor?
I can see they have a DH-SD8A240VI-HNI, which is a 2MP camera.
They did put them in the SD6 / 8 / 10 series but not sure of the 4 & 5
What do those numbers stand for (6, 8, 10, 4 and 5)?
I am the US Client that HW Andy (Hard Working Andy) sent (he did his usual great job on that, just to let ya know). The camera is the recently released Dahua SD8A840VI-HNI (4K). I wanted to wait for nice weather, but in a week I would have officially waited a year, so ... .
It still has been mainly dark, overcast and rainy with heavy cloud cover all month. So here is the screen print recording of it recorded a couple of hours ago. YouTube (on my end) has degraded the detail some, so I hope it is representative. Please compare to screen shot stills to know, they should match in detail and clarity (can you see the orange and white buoy stuck between the logs several hundred yards away on the point? The long shots of houses on the islands are 5 Miles away! The still of the Ferry is 4 Miles away.
Be sure you set the Youtube Gear icon (lower right of Youtube screen) to 4k. It should show "4k" in a red box over the symbol. At first I hadn't set that and the quality was so poor it wouldn't have be worth looking at. The Youtube link is
The clarity of the video should be the same as the attached file "screen capture from onboard 400GB SD Card Recording.jpg". This is a printscreen shot of the same video as recorded by the Dahua recorder/player internal to the camera on a 400GB SD card (yes!, it can use the 400GB card, formats to about 375GB). You may notice I don't have the highest settings for bps either, to save space. So far the 400GB has been giving me about a weeks worth of 24/7 video with the lower quality compression setting (as used here also). Let me know it the resolution turned out ok on your side and if you are interested in any other shots such as night videos or stills.
This switch has 1 Hi-PoE port and a total power budget of 60W. It's cheap and readily available.I just received the SD6AL830V-HNI from Andy/Empire a few days ago. I've done quite a few of these installs over the years, but it is not my day-job anymore. I was in a rush to order and didnt notice I needed a Hi-POE injector before installing, was a tad disappointing that I needed an extremely high wattage Hi-POE and it wasn't exactly obvious (but makes sense and is in the PDF/Specs).
For FYI; Make sure to buy a 40W+ Hi-POE injector (24v). It is not an IEEE standard, but is somewhat "standard" for these type of cameras. The Dahua branded ones aren't easy to come by, but they are available at a few places. Last two I ordered came back "out of stock" when the company tried to fulfill the order.
So far the SD6AL830V-HNI is looking pretty great. I had to lower the intensity of the laser to keep from making non-skin objects from looking weird. Benefit of the SD6AL830V-HNI is the clear faces at distance and no white-wash when night vision is on. Signal noise on the sensor isn't bad, and you can't beat the price. I think it's perfect for night if you don't care about color, and the sensor is sensitive enough to do fine till pretty low up until night switching.
I regret not getting the SD8A840VI-HNI, but will be ordering two more big 4k cameras... Anyone have any motion video from it at night in fairly low light situations? I'm really worried about motion/face blur in .02+/- lux conditions and lower. Well that and the size is huuuuge for the SD8, if I bought one for the side of the house for myself I'm not sure it'll fit reasonably.
The reason for my concern on the night color motion blur, I was impressed with overall viewing on the 6CE230UNI... but it left a lot to be desired on the street lamp illumination at around .02-.06lux (with a light meter). The parking lot that two of these camera will be installed with be similar conditions, and one well-lit area about 3 stories high. I'd love to have one color at night, but 1,800-ish is a lot to spend for an unknown blurring situation with low light on the SD8A840VI-HNI. I can't have the IR whitewashing a face zoomed in. I know the SD6AL830V-HNI will do the job great at night.d
TY again Andy! Service and contact were great, sorry I missed your messages.
