UI3 updated to the latest - Timeline not working
Sybertiger
8,342
24,885
Orlando
I've got two BI servers running, the older one on v5.3.6.6 (no upgrade support) and the newer one on v5.5.7.0.
The older one had UI3 v133 on it while the newer one has v213. I decided to update the UI3 on the older one to v213 also just so that both systems have the same appearance. The problem I have is that when I upgraded to v213 on the older system the timeline isn't working. You can see what I'm talking about from the graphics below which show the timeline on the old versus new system. I'm aware of the compatibility warning but still have a couple of questions.
Questions:
1. With the timeline feature of the newer UI3 is there a specific minimum BI version you have to have? Maybe there's a version of UI3 that has the timeline feature that is compatible with v5.3.6.6?
2. Is there something other than unzipping the UI3 release and copying all the files/folders it to the www subdirectory of the BI 5 directory that needs to be done? I copied the files/folders over when BI was still running, problem?
BI v5.3.6.6 UI3 v213
BI v5.5.7.0 UI3 v213
Answer: v197 <<<< so, v196 it's gonna be for me!
Reactions: fenderman
