Is there a way to override the default streaming profile? I was the set the default UI3 quality to 75% rather than %20 (or at least for the 1080p_vbr profile which is loaded by default).
I know you can manually change it but these get overridden when you update and needs to be set for each device, i know you could also modify it in the ui3.htm but again this gets overridden.
I know there is a ui3-local-overrides.js which i'm hoping could be used to create a custom profile that loads as default or something but i have no idea where to even start. Any help appreciated!
