UI3 shows wrong dates
flyboy68
Mar 24, 2019
72
7
Kansas
Weird issue here. BI will run fine for about a month. Then i notice clips for the last 2-3 days are missing. Right now, they dates for all 16 cameras is showing 2/19/2026 and it's 3/9/2026. The pie that shows status is red like maybe the drives are overallocated, but when I click on the pie all looks good. Did a "repair DB" anyway, same thing. Usually if i restart the pc it fixes it, but before i do, is there something else i should check first? Blue Iris is up to date, running windows 10.
Thanks for any help!
Josh
I don't see anything particularly wrong in that screenshot.
Red pie top left ... do you mean the button for opening Blue Iris Status?
I believe the red color just means you have unviewed errors in the Log tab of Blue Iris Status.
Are you still missing clips?
Are they missing in Blue Iris's local console (the Blue Iris program window) or in UI3 (the web interface) or both?
Are the clip files missing in the folders on disk where they should be saved?
Yeah the status button is what i was referring to.
Yes the clips for all cameras are missing from last friday. Both UI3 and Main Blue Iris on local console.
I'll look for the clips in the folder....
