worth a shot. if a no go, can use the HDMI cable for something else in the future.Makes me want to see if my housemates POS Nightowl would work on a 30 footer to the kitchen wall TV. Of course that creates new problems. The mouse....![]()
I use a monoprice active hdmi cable to run from my server closet to an input on my A/V receiver in my living room, so I can access see the BI cpu on my living room TV. I also ran a powered USB extender to the receiver cabinet so I can plug the mouse/keyboard wireless dongle in at the living room. I use the mouse and keyboard from the couch. I think the cables were around 50 or 75 feet. It has been rock solid for over a year."This will replace the 50' HDMI cable I have running from a Blue Iris server downstairs to my upstairs smart tv"
50 feet? how did you do that....I thought they could only be like 5-6 feet long.
is there a benefit of using a a/v receiver for HDMI instead of directly into a tv?I use a monoprice active hdmi cable to run from my server closet to an input on my A/V receiver in my living room, so I can access see the BI cpu on my living room TV. I also ran a powered USB extender to the receiver cabinet so I can plug the mouse/keyboard wireless dongle in at the living room. I use the mouse and keyboard from the couch. I think the cables were around 50 or 75 feet. It has been rock solid for over a year.
Not really. In my case, I have a Samsung TV with that goofy proprietary hdmi input box (one connect I believe it is called) with a very short 6 foot cable. I have my TV over the fireplace, so its easier for me to let the receiver do the hdmi input switching and only run 1 hdmi cable up to the TV versus having to run 5 or 6 of them up there.is there a benefit of using a a/v receiver for HDMI instead of directly into a tv?
learned really fast to disable screen saver and also to set UI3 timeout to 0 so that it never disconnected![]()
UI3 settings on the top right, UI3 timeout set to 0 for neverStupid question I’m sure, but where do you set the UI3 timeout?
