Optimus Prime Getting the hang of it Sep 29, 2014 282 30 Apr 22, 2020 #1 Hi guys. Is there a setting allowing the PTZ buttons in the UI3 interface to be larger?
looney2ns IPCT Contributor Sep 25, 2016 16,318 24,222 Evansville, In. USA May 3, 2020 #2 Optimus Prime said: Hi guys. Is there a setting allowing the PTZ buttons in the UI3 interface to be larger? Click to expand... No, but you can use the keyboard instead. See the UI3 help that is included.
Optimus Prime Getting the hang of it Sep 29, 2014 282 30 May 3, 2020 #3 looney2ns said: No, but you can use the keyboard instead. See the UI3 help that is included. Click to expand... Thanks...my use-case is phone based. The PTZ buttons are a little difficult to use on a large phone screen.
