Hi,
Don't know if this has been mentioned but I just found out about the Unibiquiti Unifi USW-Flex switch:
Ubiquiti - UniFi® Switch Flex
https://dl.ubnt.com/datasheets/unifi/USW-Flex_DS.pdf
PoE input
Power Method (Port 1)
PoE Mode 1: 802.3af/at (Pins 1, 2+; 3, 6-)
PoE Mode 2: 802.3bt (Pins 1, 2+; 3, 6- and 4, 5+; 7, 8- )
PoE Mode 3: 50V/60W PoE Adapter3
PoE output (4x, Port 2-5)
Total PoE Power Budget
Powered by AF mode PSE: 8W
Powered by AT mode PSE: 20W
Powered by BT mode PSE: 46W
Powered by PoE Adapter: 46W
(Enabled in Controller)
This seems perfect if you want to connect multiple cams where you only have one Ethernet connection. I know there are other solutions but I think this is the first (affordable) that is powered through 802.3 standards (including 802.3bt !) and provides pass-through with 4 proper 802.3af ports.
I ordered two as it fits my requirements perfectly. I think I will be pairing it with a Ubiquiti US-16-150W (which will only power it with 802.3at but that's good enough for me).
PoE input
