Two wire hikvision intercom live stream
Mar 7, 2020
3
Portugal
Hello i have an intercom system with DS-KV8103-IME2 door station.
I can access the stream by RTSP hikvision default URL, but the http still image url doesn't work. Do you know if it is supported in this door station?
Thank you!
Thank you!
Hi,
Just wondering how you are accessing the rtsp stream - I’ve tried a myriad or combinations with no luck. And the settings on the door station are limited - nothing specific to rtsp.
Regards,
Kristopher
Can you please advise the full URI you use? Also advise what username / password you use?
I've tried:
Code:
rtsp:/admin:[email protected]:554/Streaming/Channels/101
The pass I've tried is the admin password (6 digit code) on the indoor panel. Not sure what other user/pass to try?
I've tried both door station IP and the indoor station IP.
