two way audio doesn't work in IP Cam viewer
dannieboiz
May 13, 2015
498
72
I'm able to listen but can't talk back when using IP Cam viewer. I can do so from my browser. I'm using a 2532 tried both HTTP port as well as RTSP.
Since IP Cam viewer doesn't have a 2532, I select 2432 as a profile which should be the same I think. Any suggestions?
you will have to email the developer of ip camviewer...try tinycampro
