Hi
I have a mix of old analogue domes and newer IP bullits monitoring a factory.
The analogue system is starting to fail and the IP cameras were a bit by bit installation done cheap.
I'm now looking to integrate and upgrade.
Factory environment is very dusty. I don't notice a difference in performance between the types of camera and the lenses of the bullet cameras don't really seem to pick up much dust. So I figure I'm ok to use that design (or turrets) without much worry. But i don't want to end up having to clean lenses on a regular basis so thought I'd check if anyone has had experience, good or bad, in dusty environments?
Thanks
Thanks
