Greetings,
I currently have hikvision DS-2cd2132F-1 dome on wall mount. Thinking of replacing it with the HikV DS-2CD2385G1-I turret. Was told turret is better than dome, especially at night, with a larger sensor. The wall is stucco, and I would prefer NOT to drill extra holes in it. Is there a way I can use the existing wall mount? I know turret is bigger than dome. Is there an adapter I can use to utilize an existing wall mount?
Thanks
Thanks
